E3 spark plug
Kerry
Has anyone tried one yet? Thinking of trying one in my Scamp. E3-10, replaces RJ19LM Champion.
SeniorCitizen
If you've run completely out of something to do I could use some help around the ranch this summer. :laughing:
Have seen many units come in with running problems and found this plug fouled. I stick to a tried and true J19LM.
SeniorCitizen
One should be able to easily read " MARKETING SCHEME " just by the plug number.
rarebear
I have two in use for a few weeks..
They work much better than the 20 year old Champion plug I took out :)
secaII4884
I like them. Not sure they last a lifetime but I've ran one for a few years and had not a single problem.
jp1961
I use Autolite Iridium plugs in my 10323, no fouling issues. Autolite makes a quality plug, equal to NGK, IMO.
Jeff
robinb66
I personally use a champion cj8 as my general purpose plug across the board from my mower, tiller I used to own and my trimmer. Never had a prob works pretty good
primerbulb120
I agree. I think the electrodes tend to get clogged with carbon deposits. I have had two encounters with this plug. The first is on a backpack blower, where it had failed and needed replacement. The second was on a lawn mower, and the electrodes were clogged with carbon.
That said, I don't think that aftermarket plugs are a problem as long as they have the standard electrode design.
Kerry
J19LM it is. A mix of good and bad reviews has not convinced me yet.
