e start
pokeytwins
Hi, does anyone make a e start walk behind mower. 32 or 33 deck. I know ferris made one. Please no cheap models.
Thanks
Thanks
So you are looking for a commercial grade mower? Not a residential one? (like Cub Cadet's 33" Scag makes a 32", as well as Gravely and Toro. Not sure if they're electric start, but they ARE 32".
jekjr
Hi, does anyone make a e start walk behind mower. 32 or 33 deck. I know ferris made one. Please no cheap models. Thanks
Toro makes a 30". Not sure what you are hunting.
If you want a 32", you can get the Toro/Exmark 30's for cheaper like jekjr said (not saying I recommend them, because I have never used one), or you can jump up 4 inches to a 36" mower, where you get a larger choice of brands to choose from because that is a more standard deck width most manufacturers offer. Unless you want a 32" because of gate size.
jekjr
We use a Time Master 30". The one we have is not electric start but normally always cranks on the first pull. They make it in electric start though. Ours is in it's second season and has done us a good job.
LoCo86
Wright makes a 32" hydro walk behind mower. You should check them out.
