I've got a Yr 2011 17.5 B&S powertech 31C707-3005-G5 that dumped a valve. Engine shut down on me. Found bottom valve assem lose and push rod not moving with cam. I wanted ask some of you techs out there is it worth trying to fix? I didn't put a gauge to check compression but felt it through spark plug.
Thoughts...
Thoughts...
