WELCOME to LMF...
Dual wheels may increase the stability, but will also increase the load on the wheel axle, it's bearings and all the support.
Plus it will increase the damage to the grass at turns, If you make pivot turns like many folks do when they start using a ZT...
If a wider stance is going to be needed for stability... You May be on too steep a grade to operate.... :smile:KennyV
