Hey guys I'm changing the drive belt on a Cub Cadet LT1050 and the drive pulley is welded on. I've already bent it slightly trying to pull it off. I know a puller isn't the correct way but I'm running out of options. If anyone is familiar with taryl fixes all on youtube, he uses an airhammer on the pto bolt and has someone else pry down on it and it vibrates right off. Would that not vibrate the rod bolts loose inside? Other option is lightly heat pulley outer rim with heat? I'm worried I'll mess up the oil seal if I do that though. Any suggestions would be greatly appreciated!
