I HAVE AN OLD EXPLORER SERIAL NUMBER 123444 THAT DEVELOPED AN ISSUE. LAST TIME USED IT WORKED FINE, TODAY IT DOES NOT DRIVE ON THE LEFT SIDE. THERE ARE NO LEAKS AND THE CENTER AXLE NUT TURNS, THE HUB AND WHEEL DO NOT. I TOOK THE WHEEL OFF AND THE HUB ROTATES ON THE DRIVE. I DID NOT HAVE A SOCKET LARGE ENOUGH TO REMOVETHE CENTER NUT. LOOKED IN THE EXMARK PARTS DIAGRAM BUT DID NOT SEE THE HUB LISTED. I AM CALLING IT THE HUB SINCE THE WHEEL BOLTS TO IT. SO IT SEEMS LIKE THE AXLE HYDRAULICS WORK BUT THE WHEEL HUB IS DISCNNECTED, HOPEFULLY TOMORROW I WILL GET THE CENTER NUT OFF.
ANY IDEAS OR DIRECTION?
