Mad Mackie
A fair amount of brass jets have a countersink leading in.
With the drill bit in a pin vice, I start in a counterclockwise rotation and sometime go all the way thru in the same direction.
Holding the pin vice steady, I work the drill bit in and out smoothing up the new hole as best can be done.
I usually dip the drill bit in cutting oil before hand.
I don't recommend pushing thru a jet with a torch tip cleaning tool.
I have never got into motorcycle carbs, but I have a friend that does and he uses the same procedure that I do, in fact, I'm the one that showed him how back in the 70s. He is a retired machinist/aircraft specialty welder and now does rework of off road motorcycles used in competition. He has a watchmakers lathe and has made jets on it.
Most of my jetting work was done on two stroke outboard motors along with some high performance inboard/outboard boats, some of which turned up to 7,000 RPM and governed.
Number drills bits are manufactured to closer tolerances than jobber drill bits and can vary in size slightly between manufacturers. I use this to my advantage when resizing jets.
Sometimes all that is needed is .0005" more in hole size and this can sometimes be difficult to do.
