Go to troubleshooting section after posting model number. Manuals - Service - Support - Murray
Thanks mechanic man, I did that, looked all over the manual and couldn't find solution to my problem. Is there any where else I can go?
Thanks again
David
Or have you got it "cranking" but not "starting".???
You are grounding the plug, correct? If you are then have you replaced spark plug?
