brokewheelhorse
- Nov 9, 2017
- 7
I replaced the ring gear on flywheel on a 13.5 hp Briggs and Stratton and now all it does is roll over and backfires through exhaust. Shear key is good. What do I do now?
I found out the problem. I didn't have the piston at top dead center so it made the timing offPosting the Engine numbers would help so those here can lookup you engine.
And you only replaced the ring gear and not the complete flywheel, right?
