Does this machine has a 4 cycle engine or 2 cycle one?
cpurvis
  • / Does this machine has a 4 cycle engine or 2 cycle one?
4 cycle.
Your tune up probably should include a new air filter, spark plug, oil change and removal of the fan housing to clean the cylinder cooling fins and investigate that oil leak. It looks like if this has ever been done, it was a long time ago.
And sharpen and balance the blade.
jkinforjob
Thank you so much for your great suggestions. I definitely will give a try. To be honest, I almost know nothing about machine. It is my first time to do such kind of thing. Hopefully everything will go smoothly. ✌
