Does this carb have an idle adjustment?
So I doublechecked the position of the governor arm and the pin to make sure the governor was putting up enough fight. I loosened the nut and make sure it was adjusted right. It actually fired up with a little too low RPM! That was the issue. I bent the governor arm a little and that put the run speed right in range. It does idle a little slow now but finally I can adjust the idle screw to fix that. Run speed is perfect.
Thanks for the help, all!
