Threejack
- Apr 12, 2022
- 13
I have replaced the hydraulic pump housing o-ring and charge pump o-ring on both pumps on my mower. I read a lot about hydro-gear “air-purge procedure” at various places while studying up on this job. The procedure references bypass valve, but I’m not sure my pumps are equipped with them. My owners manual only references “dump valves” and indicates they are on the back of the pump somewhere and are used to move the mower without running the engine. However, I don’t see anything that looks like it would be a “quarter or half turn valve” of any nature. Additionally, there isn’t any direction of purging air after say a hydraulic fluid and filter change In the OM.
So do I have a dump valve and where is it? And do I need to do some sort of air purge?
I’ve attached a couple of pictures of my pumps if that will help.
