Does anyone know if the the Marastar 20x8x8 Turf Traction wheels made for John Deere mowers will fit the Cub Cadet xt1 mower with 20x8x8 rear wheels.
CRU
  • / Does anyone know if the the Marastar 20x8x8 Turf Traction wheels made for John Deere mowers will fit the Cub Cadet xt1 mower with 20x8x8 rear wheels.
Didn't you just answer your own question? Say it again out loud.
20x8x8 = 20x8x8 right?
sessman55
The bolt pattern on the wheels may be different between the two manufacturers. Measure the mounting bolts center-to-center. Also, the set back on the wheels may be different, causing rubbing against the frame if not correctly sized.
Honest Abe
your post is a bit "ambiguous"...
are you looking just to change tires,
or wheels/rims;
or,
both . . . ?
