Do Raptor SD hydro bracket replacement kits work on all models?
jwawa
  • / Do Raptor SD hydro bracket replacement kits work on all models?
I have two more hydro brackets broken (again) on my Raptor SD model #937854 and I want replace all the brackets with heavier duty brackets.
Problem 1: I can't find any bracket kit that explicitly lists my model #937854 as compatible. Is it safe to assume that all Raptor SD Hydro bracket kits work on all Raptor SD models? Or is there really no kit to be found for my model?
Problem 2: I've already replaced at least one of these brackets previously. Is there a specific kit (Mfr, Part #, or link please) you can suggest so I don't just replace it with another weak part I'll be replacing in a year?
Thanks!
They look the same but they do have different part numbers so you should check with the dealer for they maybe the same or not.
