I recently replaced the spindle assembly on my old Cub Cadet 2186 after the bearing froze up. All parts were bought from my local Cub Cadet dealership using the part numbers from the original parts manual. In the deck schematic it shows a "spacer, blade", pn 3102817, installed between the blade and the deck spindle spacer. As I was reassembling the spindle assembly I noticed the other two assemblies did not have the blade spacer. When I installed the spacer the spindle bolt is only able to get a few threads into the hex flange nut - see photos. The first photo shows an assembly with no spacer, the other two show the spindle bolt with the spacer installed.
Do I need a longer spindle bolt to use the blade spacer? Or should I continue without spacers? This is a very old CC garden tractor that I bought to mow our 3/4 acres and I've just used it a few times. I appreciate any advice!
