DLT3000 carb question
rainasdad
Im working on a fuel issue on this rider, it has a 18.5 hp Intek B&S single piston engine #31P777-0348E1
I need to clean up the carb, thinking old bad fuel. It wasn't getting fuel until I switched out the fuel pump with the one off my Gravley.
Once started you could smell the old fuel trying to burn-- wont stay running -
going to replace the fuel line, clean the tank, replace the fuel pump.
Any way , my question-- the bowl has a solenoid on the bottom of it, how do you remove the bowl for cleaning, as I dont see a bolt or hex nut holding it on?
Thanks for the help
The solenoid is separated from the fuel bowl using an open end wrench that has been thinned to fit between the solenoid.
The solenoid is holds the fuel on when you a Ruixing or Walbro. Nikki fuel bowl is held on by two screws.
Both the Nikki and Walbro uses a 13mm wrench and the Ruixing uses a 12mm wrench.
