DIY:K thermocouples tell engine temperature
motoman
Ever wonder how hot your sump oil or head(s) are? Maybe you should unless you're content with the short life predicted for air cooled tractors. A useful technology widely used in industry is the "K" type thermocouple. Sounds too technical? It's self powered , very accurate, and cheap (for DIY'ers). You can make an oil probe (stick it down the dipstick tube), and a cylinder head sensor (put it under the sparkplug) from the two lead K wire. Just made them and they work. Cost, $ 12.
Oh yeah... you need a digital thermometer, roughly the size of VOM (meter). Don't turn away yet. Mine is 8 years ok, cost $29. Ebay has them for $49. American made are more $.
Thermometers are not suitable for permanent mounting on the tractor. Instead, you will take periodic readings prompted by curiosity or as backup for existing gauges. Sorry for cracking the $50 DIY barrier. Tell me if you are interested and I will post two threads... with pics. :drink:
DaveTN
Yeah, sounds very interesting, show us your pix.
Give me a little more info on what you meant by putting it "under the sparkplug" please.
Thanks. Dave
panabiker
I like wireless so I use infrared thermometers. No wiring, no touching. They cost around $30 and up. The more important question is what is the "normal" temperature range for various parts and what to do if it exceeds the range.
motoman
Dave , For years VW bug and especially van owners have blown engines with regularity. The major problem was head over temp. They often install a head temp gage which is essentially a spark plug gasket with a wire to a heat gage. This approach is used in small aircraft, motorcycles, go- carts and race cars. Some have proven widely inaccurate. The K appoach remedies the inaccuracy. I will post some pics. Motoman
motoman
Panabiker, I see that the infra red units are coming down in price. I do not have one ,but how , for instance ,can you get "no fin" head readings ? Also, how can you get sump oil temp? Anyway I believe we know what the dangerous range is for aluminum heads from a vast literatue on line . I am tring to run a series of sump oil vs head temps, but that will probably not complete untill I stress my Craftsman Intek with worst case which is Spring ,3 bagigng ,on slope with damp grass. Meanwhile leaf bagging is coming up and I may be able to throw out some numbers. Motoman
SeniorCitizen
Because of curiosity only, I once screwed a dial thermometer with a 3" stem directly into the oil drain on a 12 hp briggs riding mower and the highest oil temp. recorded was around 250 F with the ambient temperature 95.
Unless there is a temperature shut down or audible warning set at a predetermined value I see no purpose since we can't mow and continually watch a temperature gauge or oil pressure gauge etc.
Constantly monitoring gauges would be similar to texting. :laughing:
panabiker
Indeed. If an engine overheats regularly in a non-abusive use, it's more indicative of some design flaw. Maybe a larger engine should have been installed on the mower.
motoman
Well Sandbur and Panabiker. I only have experience with my once ever Craftsman 48" Intek. After reading these threads for over a year I know there are better disigns out there. But what's worked for me after two self destructions is exactly monitoring an oil temp gauge, especially when I use the tractor as designed-cutting grass with a 3 bagger on a slight grade.
I have read that some better tractors have red warning lights for oil level, but not that I can recall for oil or head temp. Incidentally there's some indication of at least a plus 75F at the head over oil temp
on my unit. If that's true your reading suggests the head was entering a dangerous region. I'm just trying to set some guide lines. Of course only a lunatic fringe would pursue such an effort. :tractor:
Ariena
motoman said:
Dave , For years VW bug and especially van owners Motoman
I know this from personal experience. I solved this by 2 methods.
#1. Oil temperature sensor installed through the dipstick tube.
#2. Oil temperature sensor installed in the oil pan drain. The sensor screws into the pan instead of your drain plug.
I realize that this does not give you head temperature, but it puts you in the Ballpark!
motoman
Ariena, WIll you take my tractor and some cash for your buug? Hope it's not a garage queen.
Please tell us what ballpark sump oil temp you avoid and how you cool down if that temp is reached.....Motoman
