Homer1
- Jul 25, 2015
- 19
- 170
Our Dixon dealers are drying up around here. I planned on buying one from my local farm supply store, but they quit carrying them a couple of years ago, although I still see several in my area.
Anyway, this really sounds like a fluid or air issue to me. I'm no expert, but that's where I would look first.
On my scag, there are hoses running to the hydros from a small reservoir tank, this tank lets the fluid expand once the drives heat up, causing the level in the tank to go up some. It has to have a place to go or it will build up pressure and cause problems. I am not sure of the design of the Dixon or how they have it, but make sure the tanks if supplied aren't over half full cold, and make sure there's something in the sight window as well to prevent air from getting in.
I only know the newer style drives, so I can't speak for the older sealed style. I have an old JD hydro tractor that i've never even looked at, it just keeps running, I don't check or add. Almost afraid to![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
