Dixon ZTR 542 engine not getting fuel?
skillet30
I tried to start my Dixon ZTR 542 today to no avail. The starter Is working fine. I took off the air filter and sprayed carb cleaner into the carb. Tried starting the mower again and it started for a couple seconds. Also tried this with a little fuel. Ran for a few seconds and then died, so I guess I'm getting spark. Fuel delivery issue? There is gas in both tanks. Thanks for any help!
skillet30
The engine on my Dixon 542 is the Kohler Magnum 16 vertical shaftKohler-Magnum-16-18-20HP-500x500.jpg
Briana
Welcome to LawnWorld!
We moved your thread to the Husqvarna & Dixon forum.
