I'm new here and hope to be an effective contributor as time goes by. However, at this time I'm the one in need. My Kohler-powered Dixon Ultra 52 was recently in the dealer's shop for non-starting issues. They found that a 20 amp blade fuse was bad and replaced it. I had expected it to be the starter solenoid/relay, but, that was okay.
Now, the same problem has recurred and I am able to start the engine by bridging the solenoid with a pair of pliers, thus, bypassing the solenoid. I has tried to locate the 20 amp fuse but need your help in locating it. Plus, a question: Does that 20 amp fuse really determine whether the solenoid activates, or, not? FYI, the Dixon manuals do not cover the starter circuitry, at all, and endless Googling hasn't reaped anything useful. So here in a capsule is what I'm asking you:
1) Where is the 20 amp fuse? And,
2) What's the chance the solenoid/relay is at fault?
Thanks, fellas!
sid007 (Sid Moore)
Thanks, fellas!
sid007 (Sid Moore)
