Hydraulic line recently came off while mowing. I reset the hydraulic line on the pump (right side if your sitting on Dixie). I replaced the hydraulic oil. I jacked the Dixie Chopper up and ran it for several minutes. Then test drove it. The left side hydraulic arm stops working after about 15 minutes or the engine is hot. I re-jacked the Dixie back up and ran it for nearly 17 minutes testing the hydraulic arms. The right side is ok, but the left side stops working. No noise or that hydraulic grinding sound it just stops working and not hydraulic pressure. I lifted the seat and there is no hydraulic fluid sprayed around the engine area nor is there any on the ground. Any ideas for me? I'm not 100% sure how to bleed the air out of the hydraulic lines or maybe I have something else going on. Any help / ideas is greatly appreciated. The tractor is currently jacked up so I can test again.
Thank You
L.S.
Thank You
L.S.
