Engine distributor removal
gary sr
:confused2:2003 kubota 3 cylinder gas engine. how do you remove the factory installed distributor from the block?. has no bolt where you adjust timing, just a metal cap or cover. please help, hammer is too close for comfort.
I know this is an old thread, but did you ever receive an answer to this question? I'm having the same problem. Thanks
