Disengage Trans - Troy-Bilt Pony
Retired_6
Hello, hoping someone can tell me how to disengage the transmission on a Troy-Bilt Pony Model 13WM77KS011
I have three other Lawn Tractors plus a Zero Turn Simplicity, wife bought this one from a friend, was running perfectly, parked for a month, would not turn over, it's dead, I need to push it into my lawn shed until I a can get around to working on it.
Problem is I cannot disengage the rear wheels. There is no pin in the back to pull/push out/in. I downloaded the manuals from Troy-Bilt website. No info in the manuals.
How do I get this thing to move?
IF look on the left there is a big lever with F_N_R. N is neutral. Now you can a stuck brake calipier and that will prevent you from moving the mower.
Retired_6
There is no stuck brake caliper, the transmission needs to be disengaged.
Then either the shifter has got disconnected, badly out adjustment, or the single speed transaxle needs to be pulled and opened up as the shifter is broken internally.
