Engine Difficulty Starting Engine
JimP2014
Not sure what you mean about a "blurb"??
Were you talking about my last post?
Yes, leave the small wire at the coil {spark plug}!!!!!!!!
In no way do you want to send any voltage to the coil!!!!!! Unless you like burning $50 bills!!!!!
The wiring setup on these mowers is pretty much set up one way, the engines shut off with "grounding the kill wire" at the ignition coil. But if you keep screwing around and accidently send voltage to the coil by screwing around, you will destroy your ignition coil!!!!!
I should say this makes more sense now:
But to eliminate the kill-switch circuit, you need to unplug the small wire at the coil. And if it keeps running then, then you know which direction to look.
I am going to try this later today.
