Hi,
I have an older MTD with a 14.5 HP Briggs engine. I had it at a shop for about 3 weeks. The mechanic replaced the fuel line, the spark plug, the fuel filter and the air cleaner. I brought it to him because the engine kept quitting. So he delivered it back to me today. The driver drove it off the flat bed and shut it off. I then started it and drove it to a garage. The garage is at an incline and I shut it off again at the garage door. I opened the garage door, and the tractor would not start. So I pushed it in the garage, and tried to start it on level ground. The engine kept turning over but no start. I bought a can of carb cleaner, waited about an hour and sprayed the carb cleaner and after about 5 mins of spraying it, the engine finally turned over. I didn't touch anything and let it run for say 15 mins. and it ran fine. The reason I brought it to the shop in the first place is, it would NOT stay running. I was thinking maybe the kill-switch but the engine was cranking so maybe not the kill-switch, I am not sure about this. It is gravity fed system so maybe the incline ( where I stopped it ) made it difficult to get gas into the carb? But on level ground I would think it would start back up but didn't without the aide of carb cleaner.
Anyone have any ideas on this?
Thanks,
Jim
Thanks,
Jim
