Export thread
Differential (used) internal part needed
#1
D
donnybegood
Hi ! from Australia,
Would anyone have any internal parts for this amazing plastic what- were- they- thinking diff ?
I disassembled mine to find that the short stub shaft on the R/H side was sheared off where it is internally supported by the longer L/H shaft.
I would like to rebuild the diff and have it as a spare as the rest of it's internals are OK. Its not a very weighty item, so may not cost much to ship to Australia .
Cheers .
#2
D
donnybegood
This is the short shaft with the external gear cog removed. The broken piece , about 1.5" long is shown standing on its end.
This is the shaft with the broken piece superglued back in place - for identification purposes only !
I am wondering if it could be silver soldered back on ? Anyone tried that with this type of shaft in any device ?
#3
B
Assuming it is a General Transmission unit, service replacement parts are available directly from General.
Sip also make plastic drives but AFAIK no mowers sold locally have them fitted.
And no you can not repair that shaft by silver soldering, in fact even welding would be highly likely to fail in that position.
And if Donny was really good he would have mentioned then make & model of the mower he is trying to fix.
#4
D
donnybegood
Hi All,
Sorry, I thought I was in a Weedeater One Forum. I see its a general Weedeater Forum, which obviously covers all their products !
Machine is a Weedeater One (Mowcart 66 in Australia).
Thanks,
#5
tom3
tom3
That broken shaft extension looks to be separate part from the outer sleeve gear. I suspect the shaft maybe could be pressed out of the sleeve and a standard piece of shafting inserted? Might be an interference fit that will need heat? Interesting machine there. 11 cubic inch Briggs engine on a rider, not real common.
#6
B
There is only 1 forum.
It is broken up by brand to make it easier to search for information.
There are no single model sub groups here.
#7
D
donnybegood
Thanks Tom 3.
Ive been out of action for a week, hence my late reply.
Will disassemble the diff again and have a good look, but from the external view, it doesn't look like its an internal separate shaft.
And if it was pressed in from the other (internal) end into a blank hole, I wont be able to press it out. But will look for and respond again.
I think from over-googling, that Dixon make this diff, as jacks small engines in the usa stock it. I bet Dixon wont sell me just the shaft though!
#8
D
donnybegood
Thanks for that Bert. General don't have this diff, and Ive emailed Sip in the UK to see if they do. I'll try Dixon in the USA, as they do make a replacement unit.
Someone, somewhere, will have one of these plastic diffs hurled into the corner of their shed. I'll keep an eye out for a "Free Mower" ad !
BTW, after pricing most of the parts from the USA, it was not much more ($50.00) to buy the complete transaxle from a local Husky dealer, which comes with the 3 x chains as well. I was going to buy the chains from Bearing Service.
Im going to disassemble the unit when it arrives though, check the grease in the diff, and fit grease nipples to all accessible bushes.
#9
B
Double check what grease you use as a lot f them are in a solvent that can soften some types of plastics.
#10
D
donnybegood
Thanks again. I wouldn't have thought of that. Found this on the web regarding this issue :
https://www.machinedesign.com/mecha...ubrication-tips-plastic-gears-and-more-part-2
#11
tom3
tom3
Very good article, and simple enough for even me to understand. Thanks for posting the link. Always wondered about lubing plastics.
#12
A
(Account Closed)
As you have nothing to loose, before replacing a weak designed part, I'd attempt to modify / fix it.
To remove the broke part, either drill the plastic, put a sheet metal screw and yank it out or simply melt it out.
Now the fun part. Find or have machined an identical "rod" that fits snug in the NOW open hole. Some RED Loctite will keep it from moving (remember, it was just plastic before). If that rod is a "standard dimension", even easier-cut to length, clean up and install...
#13
D
donnybegood
Thanks for replying. Unfortunately, the broken piece is the 40mm approx supporting end of the r/h side steel drive shaft . See my 2 x photos on page 1.
This broken off end piece locates inside the l/h drive shaft. It will be hardened steel (or should be !). I think Im snookered , unless Dixon could sell me this short r/h shaft.... or someone has one of these plastic housing diffs in the shed with another problem besides a broken short shaft !.
