I have the Husqvarna YTH 18542 riding mower with the B&S 330000 series engine that has 75 hours on it and was purchased March of 2019. I don't think I have a problem with the decompression mechanism being broken but not certain. This season, after changing the oil and running it for about 15 minutes to pick up some debris on the lawn, I shut it off. Came back a little later to put it away and when I hit the switch, it balked at starting. Tried it again and it took right off. I know the battery is good (put a light charge on it before installing this spring) and the starter appears to be working ok. Did the usual checks for loose connections, everything is clean and tight. So I started to look at youtube vids and found the problem with decompression mechanism for this 18.5 HP Intek engine. They show how to replace the camshaft and it doesn't look too difficult but not sure I want to tackle it. I probably need to check the valves first and adjust them as that hasn't been done since I purchased the mower.
So my question is: Is it possible to install a different engine like a Kohler on the mower and just get away from the Intek altogether? Will a Kohler from another size mower fit on the 42" model? I'm sure it would be cheaper to fix the B&S engine but from what I'm reading and watching videos about, it seems it's a flawed design that will fail again.
Looking for opinions from people more familiar with repairing this engine/mower than I am.
