Munchie#1
- Mar 19, 2023
- 3
So I am considering changing batteries - some of mine - at least 1 - I suspect is going dead.
I looked at part numbers and I don’t see a difference between the two models - 75ah or 100ah - other than the obvious - battery and spacer needed for the 75ah model.
So my first question is - if I go with 4 new 100ah batteries do I need to change anything, including charger - control units etc…..
secondly - if I go with LiFePO4 batteries either 75 or 100ah , do I need to make any changes then.
thank you all for reading and keep the rubber side down.
thanks
Laz
thanks
Laz
