Did I total my mower?
I have a 2006 195cc 6.5 HP Toro (LEV120 - 361541B) self propelled stand behind mower that I purchased from the original owner who ran it using 2 cycle tru-fuel (which I continue to use per his recommendation).
I'm a first time mower owner and I have been running it for a year and a half with no maintenance other than topping off the oil. The neighbor borrowed the mower and when they returned it it would still start but not stay on. That's when I began googling and realized that I should have been changing filter etc. So I bought a maintenance package off of Amazon that includes my model and specification number (Amazon product title: Hayskill 640350 Carburetor Replace for Tecumseh 640350 640303 640271 for Toro Recycler 640271 640303 LV195EA LEV100 LEV105 LEV120 20016 20017 20018 6.75 HP).
I cleaned up the mower and motor, changed out the oil, replaced the carborator and hoses, replaced fuel filter and spark plugs, removed and sharpened blade. Put it all back together as it appeared before. When I started it up it made a very loud clanking noise (no normal mower noises) for a second or two then turned off. Now if I try to start it it feels like its trying to pull the cord out of my hand at times and doesn't attempt to start up. Waited 30 mins and tried again.
Tried putting old spark plug back in and start it up. No change.
I Had noticed before installing the carb that the choke plate wasnt closed entirely like the original carb when at rest. Instead of unscrewing the screw that controls that, I determined how many turns would close the plate, then set it back to where it was incase it was supposed to be that way. Tried releasing the screw after starting it the first time, also made no difference.
I tried to figure out where I went wrong but everything about my install and maintenance looks right and nothing on the mower that I can see looks broke. where did I go wrong? What can I do to find out what went wrong?
Pull the flywheel off, sounds like the flywheel key is bad or slopp. When the engine pulls back it’s because the timing is off.
Borrow your neighbor's car to go get the woodruff key.
Then back it into a fire hydrant on the way home.
No need to say anything because it's not important. ?
I would replace the $0.10 woodruff key and try it out before taking the machine anywhere.
That sounds to me like your neighbor hit something that stopped the engine suddenly. It may have sheared or partially sheared the Woodruff key which locates the flywheel on the crankshaft, thus establishing the timing of the ignition.
Never lend your tools, equipment, vehicles or girlfriend. They will not come back in the same condition as before.
Your engine is destroyed. Likely ran without sufficient oil. Tell your neighbour to buy you a New comparable mower or never speak to him again.
It's completely sheered off.. I have a feeling the clanking noise that I was hearing was said chunk of metal flying around while the flywheel attempted to spin without it. Just need to find the part and figure out how to replace it and maybe we'll be up and running!
I was a day away from buying an electric and putting the toro away for a pet project when I have time. But thanks to you, maybe this will save it.
You would not hear the KEY clanking as it is too small and captive in its' location. Engine is destroyed. Bent rod likely. Can you see the piston going up and down via the spark plug hole? YOU didn't Total your mower, your Neighbour did. He owes you a replacement in kind.
After reading your initial post, that was also my first impression: the motor is firing at improper crank angle. I have had this happen on a similar motor.
If not the key, the "clanking" could be something in the crankcase. Last time I saw that was when a friend's son was playing around while he left to get oil for an oil change, and the son dropped the 1/4" cast iron oil plug down the oil fill funnel. Friend found the plug missing, and bought a new one. Screwed it in, added oil, and fired up the engine. Boom. Blew a 2" hole in the side of the crankcase.
And then there was the time I loaned my Kubota to a neighbor, and they called me to come get it because it quit running. She let her son run it, and he set the "throttle lock" too low for the load, and spun the spline to a toothpick. She hasn't been cordial to me ever since. Funny how that works....
Dang! I've been thinking about this "loan to a neighbor" thing, and it just doesn't work.
Loaned my Volvo sport sedan with a finely-balanced engine to a friend who was in his rookie year SCCA, and told him "no screwing around!" -- he just wanted to ferry somebody to a park entrance to get entrance tickets. He came back in a different car. He innocently described it this way: "The guy was just commenting on how smooth the engine sounded, at around 6 [thousand rpm] grand. Going into a left turn, I said, 'watch this!', and downshifted [that's now 8 grand]. When we came out of the corner, it was making lots of noise." He had spun the crank bearing on #4.
Loaned money to a couple of friends, and said "we'll not talk about this again. Pay it back when you can". Never heard from either one again. Well, at least we didn't talk about MONEY, right?
Folks use seldom-run gas equipment, and don't turn off the gas feed and empty the carburetor reservoir before storing it, guaranteeing a carb cleaning the next time I get it out
And tools STILL keep disappearing from my barn....
(sigh) So it goes. Now I just offer to do it FOR them. I could be upset, but then I think about all the things God has forgiven ME for, and bow my head in gratitude.
I hope you get your engine fixed. May God grant you insight and guide your hands!
Thank you all for your input! I ordered a Tecumseh key and replaced the broken one. While double checking everything, noticed that the nut holding the blade had come loose and got it real tight (might need to loosen and add locktite later). Possible that the blade had been loose enough to rattle (maybe even sheer that key?) Either way, it started up immediately and runs awesome! runs better with the old spark plug than the new one, so I might try another brand on that.
I agree on loaning out items with motors... I let someone test drive my van the other day and I ended up with a seized caliper. Luckily it came loose right away when I lifted the van and rotated the tire. Seems like older cars (and apparently mowers) need a special kind of care that not everyone is familiar with. Sometimes you have to form a bond of sorts, pick up on all of your vehicles preferences etc.
Anyhow, thanks for all the help, couldn't have gotten it done without it!
