Amateurhour
- Jun 12, 2021
- 1
- 5
I have a 2006 195cc 6.5 HP Toro (LEV120 - 361541B) self propelled stand behind mower that I purchased from the original owner who ran it using 2 cycle tru-fuel (which I continue to use per his recommendation).
I'm a first time mower owner and I have been running it for a year and a half with no maintenance other than topping off the oil. The neighbor borrowed the mower and when they returned it it would still start but not stay on. That's when I began googling and realized that I should have been changing filter etc. So I bought a maintenance package off of Amazon that includes my model and specification number (Amazon product title: Hayskill 640350 Carburetor Replace for Tecumseh 640350 640303 640271 for Toro Recycler 640271 640303 LV195EA LEV100 LEV105 LEV120 20016 20017 20018 6.75 HP).
I cleaned up the mower and motor, changed out the oil, replaced the carborator and hoses, replaced fuel filter and spark plugs, removed and sharpened blade. Put it all back together as it appeared before. When I started it up it made a very loud clanking noise (no normal mower noises) for a second or two then turned off. Now if I try to start it it feels like its trying to pull the cord out of my hand at times and doesn't attempt to start up. Waited 30 mins and tried again.
Tried putting old spark plug back in and start it up. No change.
I Had noticed before installing the carb that the choke plate wasnt closed entirely like the original carb when at rest. Instead of unscrewing the screw that controls that, I determined how many turns would close the plate, then set it back to where it was incase it was supposed to be that way. Tried releasing the screw after starting it the first time, also made no difference.
I tried to figure out where I went wrong but everything about my install and maintenance looks right and nothing on the mower that I can see looks broke. where did I go wrong? What can I do to find out what went wrong?
