LawnBoy97
- May 30, 2012
- 33
- 223
So I just bought a craftsman 22 inch self propelled lawn mower with a 6 hp briggs engine. It would start, but not run, so I was able to get it at a good price. So I got it home and removed the air filter and carburetor. I then cleaned the carb and replaced the fuel line. SO I got this all put back together and start ed it. It ran but there was smoke coming from around the muffler:frown:. So I then found and removed a huge mouse nest and then put it back together. I then changed the oil and started it up. Still smoking from around the muffler. so I called it quits and started to clean up all of my tools and junk when I noticed the small angled rubber tube that goes between the air filter housing and the metal tube coming out of the engine right by the carb.. So I quickly put it back where it went and started it up. I ran it for a little while and shut it off. Still smoke. So could my little mishap have caused this problem, or do i just need a new muffler? And what role did the little rubber tube play in the running of my small briggs? Thanks.
