Did I bypass blade switch correctly
JDE123
I use my Husky LTH1342 tractor for getting about the property and pulling small trailer. I removed the mower blade deck due to bent shaft. Now that tractor does not start [There is a click when i turn the key but nothing else] I am trying to eliminate possible causes. So I cut the wires for the blade switch, thus removing it. I taped the two blue wire together, taped each white wire separately, and taped the green wire separately ( I did not attach the green wire to anything).
Did I bypass blade switch correctly?
