Alright folks, I need the pros and cons of the tecumseh float vs dippy carb to make a decision on what to put on my sketchy tecumseh HS40 powered mountain bike
And I'm talking the tecumseh specific pros and cons of the carbs, I know that diaphragm carbys operate in any position.
I mean, what are performance and reliability pros and cons, do they perform equally? is one better than the other? Can a dippy carb support as low of an idle as the floaties? response time? reliability? Venturi size?
You see, I hate the float carbs, I have terrible luck with them. It seems every 3 months I need to retune it. The floats occasionally sticks opens and pisses all the fuel onto the floor, and this is with like 3 different carbs, not just one. Every bump I hit seems to make the engine run funny, probably the float bouncing around. But I understand many minibikes used the standard float carbs, so they must not be that bad I guess, maybe I'm doing something wrong. I thought about swapping it with a tecumseh diaphragm carby since I've had great experiences with walbro pumper carbs in the past. But I dont want to lose power, I like a nice responsive hesitation free engine, and there just isn't that much info available about these things, Like Im not even sure if they have fuel pumps built in like the walbros do.
