Hi Liuffydog,
No I haven't checked the condition of the battery but will do so. I did notice in one of the screen shots you sent that possible causes included a faulty battery and I did plan on following that clue today. The screen shot also mentioned a coil and a switch. In my case I presume the coil is actually the armature so I presume I should be inspecting those and checking the air gap, correct? What is the "switch" that I should also be checking and how should I check it?
Am I right in thinking my amp reading can be regarded as "significantly below" the expected amps?
Again, many thanks for taking the time to help.
Cheers, Peter
