wheelerdan
- Jul 6, 2019
- 6
If you have read my previous posts, I have rebuild the deck on this 10323 LB. Did the carburetor thing and now have it running correctly. I am now trying to figure out what the drive unit doe snot drive. When I pull the bail it bumps forward with a jerk and then nothing. It also will not pull backward until I go forward a bit, then it rolls, but drive unit does not drive. I installed a new belt. when I pull the bail the drive pulley definitely turns but it doe snot move the mower. During the deck repair I definitely had the drive unit completely apart. I replace the grease in the gear box. I think I re assembled correctly according to the parts drawing, but something is wrong. How can I diagnose and correct. What procedure should I follow to diagnose this condition. Thanks very much.
BTW, the deck was welded, then fibre glassed under side. Top side got less glass and resin over any and all rust. Painted the whole thing. She is pretty good and definitely serviceable. I just need to solve the drive unit problem.
