Mike69
- Mar 10, 2023
- 2
- 9
My wife got a deal that we could not refuse on a clearance ZTR mower at her work place so we purchased it. It is a 2022 model DeWalt (made by MTD) Z148 48" cut 23 hp mower. I start it up & it runs fine as long as the blades are not engaged, once the blades are engaged it randomly will start to run poor & blow grayish/white smoke then clear up & run ok again for a while then act up again. I read on here that it could be a carb problem as the mower has the Kawasaki FR691V engine in it. I pulled the dip stick & it smells like gas & the oil is above the full line on the dip stick. I am going to change the oil & filter & check the float bowl for any contaminants & the float to make sure it is seating properly. That is all I can think of, any other ideas or suggestions?
