Boudreaux In Eunice La.
You are right, but that carb and tank can be used on the 60000, 80000, and 90000 series engines. It was one way we used to increase hp on the 3.5 hp engines. That was before we would sand heads, punch jets, and restrict airhorns to increase power. Even built one of these. https://m.youtube.com/watch?v=AMsXKkIuaPg
Yes you can increase the HP for a 60000 by putting the carb from a bigger engine that's how Briggs did a 2 hp to 2 1/2 HP actually...... The 60000 had a vacu jet carb and the bigger 8 and 9 series had a pulsa jet carb.........
I will check your video out also.......
