OK, so I got the terminology wrong, I’m sorry. Yes I’m talking about that large gear with the lobe on it that takes the compression away while the engine is cranking.First there is no decmpression valve on today’s small engines. Depending on the age of the engine you have an ACR (auto compression release) mounted on the camshaft or a small bump on the intake lobe of the camshaft.
