Deck swap lawn boy
jim97
Will a 10304 deck replace a 10324 deck 10324 is rotted out i can get the 10304 used Thanks any help would be great
They are the exact same deck except that the 10304 deck has a hole for the sp belt to connect to the crank on the bottom of the deck. The only real difference is the sp belt cover on the duraforce is taller than the v series since the belt connects to the crank on top of the deck on a duraforce. Should work perfect!
Thank you very much
