deck drive
sammorgan
Hello, i have a yth2348 husqvarna and was cutting grass and suddenly the blades stopped turning.the belt is still on and the blades are free.this mower has the electronic blade engagement system.
Micah Haarhoff
Check if the belt is still on the "DECK CLUTCH" you probably already have though.
reynoldston
As I see it the very first post said (the belt is still on) over a month ago. Mechanic Mark summed it up very good on the second post as a PTO clutch problem with all the information to repair it.
