have a model 138-633-019 agway made by mtd 1988 year with 38" deck.
this deck mtd #753-04376 uses a #754-0329 v belt (5/8 x 69), front stabilizer rods #711-0790
that fasten to the stabilizer shaft assy just behind the front axle.they are spring loaded
by a spring that hooks on a cross rod under the right front running board.
the belt is correct and the motor pulley is not rusted.
deck does not disengage when handle is pulled back to disengage position.
pulley brakes appear to be ok. deck does not appear to move forward when
handle is pulled back and three belt keepers are in correct postion on engine pulley.
hoping someone has had this same problem and was able to correct.
picture shows my deck.
