Deck belt too tight
Tiger Small Engine
There's no adjustment. Thanks. It's 07 Pony
Before installing any new belt, simply compare the new and old belt. Put belt under arch of your shoe/boot and tighten belts with your hands and look. I do it every time before installing new belt and really aids in confirming correct belt size.
13AN77TG7?? series. Two different models showed up. Both uses the same 1/2 x 96.5 v-belt. 954-04060C (Stens 265-201).
Make sure the v-belt is inside the belt retainers. Also make sure the idler arm is free moving and the engagement is free moving. Both can bind from rust.
