Deck belt to short on Husqvarna 1542XP
in the future, if an old part does not fit with exactly the same error, the problem is not the part.
How to avoid hitting roots and rocks in the yard. MOW HIGHER!
OR clear the roots and trash. Tannerite, picks and shovels, high lift car jacks and so on.
Old timers used to walk to yard prior to mowing. Saved a lot of head aches.
With my retired mechanic neighbors help we managed to get the belt installed. He fashioned a wire to pull the tension pully forward to get enough slack to get belt installed. just cut my back yard mower cuts great and deck is quieter than it has been for a good while. Thanks to my good neighbor
A ratchet strap works really well to pull the tension idler back to install the belt.
Most people mow their grass too short any way.
As least they are not like one of my customers that get out the caliper to check the grass height.
Every grass has different cutting height. Some like it high, some like it short. Now during mowing the cutting height need to be raised high as the dry season comes into play.
So you hadn't pulled the tensioner to get the belt on I take it.
