DEATHTRAP
kozy01
Worst pushmower I've ever seen! Blade is bent, crank possible warped, had to glue a drive wheel back together, had no oil in it, the air filter was completely toast, the thing is a freak! It ripped the pull cable out of my hand almost broke my finger! Bolts that hold frame to engine are stripped! Should I just tell the people this thing is way too dangerous to operate? It looks about scrap or a 10 dollar mower. Poor thing.
kozy01
<img src="http://www.lawnmowerforum.com/attachment.php?attachmentid=16380"/>
Blade is also worn so bad that it can be seen in the photo. Needs a discharge shut, if you are a repair shop be fore it can go out. As we say, "Scrap the Caddy Clyde"
kozy01
Ha Mr Eastwood. The engine surprisingly runs pretty good so I think ill just keep the engine.
