Do you know if there is one in existence? Looks like you are in the business. Does briggs make a clone? Main features are 1 1/8 x 3 power shaft and 1 x 2 front shaft that sit about 6 3/8 off the mountsLooks like Kohler shows short block only, no complete engine replacement
should mention, fan faces rearward. I still call that the front of the engine. small shaft is on fan end. overall length is around 18 1/2Do you know if there is one in existence? Looks like you are in the business. Does briggs make a clone? Main features are 1 1/8 x 3 power shaft and 1 x 2 front shaft that sit about 6 3/8 off the mounts
Yah, the driveshaftMain question might be does that front stub shaft connect to anything?
