deacon
deacon
i have a 46in poulan pro zero turn mower,when cutting high grass blades stop turn at times what is the problem?
First get us a model number so we can see what you are using. the other thing is what are you doing at the time the blades stop. Are you cutting tough grass, or maybe pulling both direction levers to go backwards, which is causing it to disengage the blades. What year is the mower with hours if available.
