Dan mitro
Dan Mitro
Hi few days ago I parked my D125 in garage wich I got on May14-2015.It starts perfect but now it want move forward or rewers.The belt is ok and the lever on the back is out not in park position.Can you help:smile:
Don't be afraid to push it in with your foot with authority. If that doesn't correct the problem it be time for warranty work.
Rod has to be all the way in to work, once in you should not be able to push the lawnmower.
This mascine is actiting very strangly.With the rod in at first I was not able to move it at all.Now after all when the rod is in it works but when is out one can push the mashine by hand any where????
