So is the bypass rod pushed in at the back, I have a D110.
Yes the rod-lever on the back is out
Try it with the rod pushed in...
This mascine is actiting very strangly.With the rod in at first I was not able to move it at all.Now after all when the rod is in it works but when is out one can push the mashine by hand any where????Don't be afraid to push it in with your foot with authority. If that doesn't correct the problem it be time for warranty work.
