Hi there - I had started another thread that got me to this point, but I think the thread died. Was getting great help from ILENGINE and MowerPro2, but I haven't heard back. I'll re-post my last post from there here to try to fish for ideas: I have a Poulan Pro PR45Y22SB, B&S motor# 10G902 0260 B1. Where I'm at now -- I think I might have damaged the governor/slinger. Is this even possible? I replaced a governor link that got bent. It was VERY obvious that the old one was mis-shapen - too long, to be precise, and so was keeping the idle high when the governor was adjusted in the static position. Well, when I installed the new link, I readjusted the governor for good measure, and cranked her up to an awful racket and lots of sputtering. That's when I discovered that I wasn't careful and the throttle lever had jumped the stop before I adjusted the governor. I know - Duh. I shut her down, put the throttle lever back over the stop, and readjusted the static position, and now it runs, at a good idle speed, but it "sputters" for lack of a better word, and there is a faint noise going on, like a fishing reel. At first I described it as surging/hunting, but it's really more like a random sputter followed with a surge, almost like a misfire. It runs pretty smooth between sputters, tho, with no noise. Is it possible to damage the governor from misadjustment? Could this be a coincidence and something else actually be going on? I had read that excessive idle speed could crack the coil.... and it was running really high, like 4000rpm+ before I replaced the link. The bottom line is, it runs -- I was able to mow the yard with it, in fact, it ran better with the drive wheels engaged than at idle, and it ran better as it got warm. Any ideas before I just let it run itself into the ground? It's a ten year-old machine, but I'd like to keep her around for as long as possible. Thanks so much for any help you may be able to offer.
