D160 carb issue
Bob1197
So I had taken my D160 to the repair shop to correct an electrical issue that I couldn't find. When I picked it up, it fired up immediately. When I got it to the house, it fired up but was a little slow at it. The next day it cranked but would not fire without ether. I've got fuel into the carb but not out of the carb. I removed and completely cleaned the carb and replaced the gas since it wasn't just real fresh. The results are the same. Every now and then it will fire on it's own but will only run about 5-6 seconds.
It seems that my two options are to rebuild the carb or just replace it.
The carb is a Nikki 795450
Thanks
